Date/Time: Sat, 04 Jan 2025 07:39:00 +0000
Mini-DAX Futures data problem - cannot get rid of spike...
View Count: 849
[2016-05-31 10:43:38]
User51760 - Posts: 108
Dear Support Team,
there is an unusual spike on my Mini-DAX Futures (FDXMM6)charts. I am using the Sierra Chart Real Time datafeed in connection with InfinityFutures/Transact.
Menu > Edit > Delete All Data And Download does not change anything, Menu > Edit > Reload options do nothing.
What am I missing? Any idea how I can get rid of this spike since I do not believe it was ever present (I checked on the EUREX FDXMM6 website). Please refer to the attached screenshot.
Thank you for your help,
Best,
Chris
imageFDXM_160530_2200_spike.png / V - Attached On 2016-05-31 10:42:06 UTC - Size: 316.56 KB - 260 views
[2016-05-31 16:43:20]
We are checking on this.
[2016-05-31 16:59:46]
We have checked three different data feeds, and they all show that same price movement for the mini DAX. It is correct.
Date Time Of Last Edit: 2016-05-31 17:00:02
[2016-05-31 18:20:45]
Dear Team,
thank you so muuch for the investigation and the feedback.
I need to figure out what happened since the FDAX does not show this spike.
Have a great day,
Best,
Chris
[2016-06-01 15:18:27]
Just as a feedback - the Sierra Chart realtime data feed was completely correct.
I veryfied it with the official EUREX datastatistics - please refer to the screenshot.
Probably somebody was happy to move the market...
Thank you for your fast response and checking - and sorry for the false alarm.
Best, Chris
Date Time Of Last Edit: 2016-06-01 17:58:50
imagefdxm_spike_eurex.png / V - Attached On 2016-06-01 17:58:29 UTC - Size: 45.46 KB - 245 views
[2016-06-01 17:03:02]
OK thank you for the information. But we do not see a screenshot.
[2016-06-01 18:37:03]
Post #5 updated with screenshot...
Sorry and thanks.
