Date/Time: Sat, 04 Jan 2025 07:02:56 +0000
Daily bars not appearing for some Globex
View Count: 1030
[2016-05-31 00:19:56] |
cmb999 - Posts: 211 |
the 5/31 bars for NIY and NKD are not showing on chart after 6 pm (est), even after refresh ES is ok |
[2016-05-31 00:21:00] |
This is due to the holiday. You need to check the exchange website and if at the end of day tomorrow, you see end of day data on the exchange website which does not match the daily data provided by Sierra Chart, then let us know and we will look into it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-31 00:27:01] |
ok, but why ES have daily bar, not NIY or NKD Globex they are all trading, |
[2016-05-31 00:47:18] |
Check the CME website. We see no data for May 30 yet.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-31 00:47:36
