Date/Time: Sat, 04 Jan 2025 07:18:09 +0000
ACSIL symbol rollover
View Count: 731
[2016-05-30 19:58:12]
enemyspy - Posts: 306
Hi I am looking for a way to tell my custom studies that a symbol rollover is happening, and possibly some information about the rollover. For instance in the case of a back-adjusted rollover. I would like my studies to know the back_adjust value so that the studies will then update their file systems accordingly. Would Sierra Chart consider adding this to the the header file?
