Date/Time: Sat, 04 Jan 2025 07:02:47 +0000
Change color on data hit/cross
View Count: 757
[2016-05-30 08:39:13]
User740709 - Posts: 153
Would it be possible to rework and split the option of data hit and data cross into candle close hit and full candle cross?
I think that might serve the purpose a bit better.
Thanks.
Date Time Of Last Edit: 2016-05-30 08:56:34
[2016-05-31 01:37:19]
No this is not going to be done and that setting is going to get removed soon and be integrated in with Chart Drawing Alerts.
You will need to use the Chart Drawing Alert functionality for what you require:
http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartDrawingAlerts
Date Time Of Last Edit: 2016-05-31 01:57:47
[2016-05-31 06:39:01]
Thanks!
Cheers.
[2016-05-31 06:55:32]
This has been completed and will be out in the next release:
So you will be able to accomplish what you want.
