Date/Time: Thu, 16 Jan 2025 19:07:48 +0000
SaveChartImageToFile
View Count: 1469
[2016-05-30 06:39:04] |
onnb - Posts: 662 |
is there any chance that you will expand this to something like: SaveChartImageToFile(string filename) or SaveChartImageToFile(int chart_number, string filename) in the above, would like to specify a filename and if possible, would like to specify which chart to save. |
[2016-06-01 10:57:27] |
We will have to see about this.
[2016-06-01 17:26:17] |
User754985 - Posts: 109 |
+1
[2016-06-01 17:29:11] |
onnb - Posts: 662 |
Would also be nice to have boolean parameter to include overlays.
[2016-06-01 17:57:55] |
tradernikki - Posts: 41 |
+1
[2016-06-01 19:01:35] |
Willson - Posts: 176 |
Like Would also like to assign or have built-in shortcut keys |
[2016-06-14 18:21:12] |
onnb - Posts: 662 |
I have noticed that SaveChartImageToFile does not work when chart is not visible? Somewhat expected but can you confirm that this is true? Date Time Of Last Edit: 2016-06-14 18:22:50
[2016-06-15 17:42:13] |
We will be looking all of this over as soon as possible. The function should still work even if the chart is not visible and we will make sure this works properly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-15 17:57:29] |
onnb - Posts: 662 |
What is really needed is something like this - SaveChartImageToFile(int chart_number, string filename , int width, int height) Sorry for posting mql4 link here, but something along the lines of this - https://docs.mql4.com/chart_operations/chartscreenshot As you can imagine, there are many applications to a feature like this. |
[2016-07-20 08:31:45] |
There is a new ACSIL function for this: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scSaveChartImageToFileExtended Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-20 08:32:14
[2017-11-20 19:19:33] |
With the function linked to in post #10, previously overlays were not supported, but they are now.
[2017-11-21 00:04:53] |
Usermb - Posts: 126 |
This is awesome, thank you very much for doing this.
