DTC Protocol Discussion Forum
Date/Time: Tue, 04 Nov 2025 15:43:08 +0000
BuyRolloverInterest (Security Definition Response)
View Count: 3332
[2016-05-27 15:30:37]
vbmithr - Posts: 204
Daily interest AMOUNT in what unit? The amount depends on the size of the position, I guess. You mean rate?
Thanks to clarify.
[2016-05-29 06:25:16]
DTC Engineering - Posts: 320
We are not sure about the answer to this question. The server provider has to use this field in a way which is appropriate for the particular trading service being implemented.
[2016-05-29 06:32:32]
Oh OK you mean Sierra Chart is not using this field then?
[2016-05-29 07:06:12]
It is used with currency trading services like FXCM and it is in the quote currency of the symbol that it is for, but I am not sure of the particular units.
It might be per standard lot size which would be the number of currency units for a single "lot" being traded. For example trading 10,000 of EURUSD which could be considered a single lot.
Date Time Of Last Edit: 2016-05-29 07:13:35
