Date/Time: Wed, 01 Jan 2025 14:00:52 +0000
Using Visual studio c++
View Count: 887
[2016-05-27 03:04:15] |
User754985 - Posts: 109 |
Is the recommended version 2010? Trying to install VS c++ 2010 leads to an error (see attached): newer version detected. I also have v2012 and 2015 installed. Please advise. |
VS2010redistributable_error.PNG / V - Attached On 2016-05-27 03:02:24 UTC - Size: 18.32 KB - 292 views |
[2016-05-27 03:06:18] |
Or VS 2010 SP1 should be installed?
[2016-05-27 03:35:58] |
You can use whatever version of Visual C++ that you want. It is perfectly fine to use the latest one. As far as these particular errors you are encountering, they are not within the scope of our support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
