Date/Time: Wed, 01 Jan 2025 14:04:26 +0000
Interactive Brokers corn data
View Count: 724
[2016-05-26 21:16:31]
skelcap - Posts: 139
ZC-201603-ECBOT.scid file is empty. Contract roll doesn't show on chart even though log says it is being taken into consideration for continuous contract:
ZC-201607-ECBOT [CBV] [M] 30 Min #1 | Volume based rollover from ZC-201512-ECBOT to ZC-201603-ECBOT occurs at 2015-11-23 | 2016-05-26 16:51:08
[2016-05-26 21:46:41]
This is easily resolved by re-downloading data starting with the ZC-201512 contract. Follow the instructions here:
http://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading
[2016-05-27 01:57:43]
That worked thanks. Previously I tried right click on the chart in 2015 -> Delete and Download data which didn't work. I thought that should do the same thing but it seems that only updates the current contract correct?
[2016-05-27 02:07:11]
Yes.
