Date/Time: Wed, 01 Jan 2025 13:25:31 +0000
Hide Chart Drawings function
View Count: 922
[2016-05-26 20:14:04] |
User723043 - Posts: 11 |
Hi all, I've noticed that if in an active chart the drawings are copied from other charts (setting it in "Chart Settings/Advanced Settings 2/Copy Chart Drawings From Chart #'s"), choosing "Hide Chart Drawings" in the active chart the copied drawings are not hidden but are hidden only drawings created in the active chart. If I'm not wrong (I'm not sure 100%) in previous versions choosing "Hide Chart Drawings" in an active chart were hidden all the drawings, those copied from other charts and those created in the active chart giving you the chance to switch quickly from a drawn active chart to a "clean" one and vice versa; It would be very useful and handy this feature! Thank you.
[2016-05-27 04:53:01] |
This was changed based on user requests. There is now a separate command to hide drawings from other charts. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_ChartMenu.html#HideChartDrawingsFromOtherCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
