Date/Time: Wed, 09 Apr 2025 02:34:04 +0000
New user ? I want to create a drawing tool and have it accessible from menu
View Count: 622
[2016-05-25 17:45:53] |
JohnR - User831573 - Posts: 330 |
I want to create a drawing tool or modify an existing one and have it show in the list of possible draing object in the menu system. How does one do this? For example, I want to take the existing Pitchfork tool, and expand it's capabilities to draw additional line. To accomplish this, I would need to read / get the 3 points used to create the instance of the fork, and then use those in my calculations. I am thinking I want to do this as a tool vs indicator, so when I move / adjust the fork location on the chart, all lines original and my added ones will be redrawn in the correct locations. Thanks in advance for your time to reply. John |
[2016-05-25 17:59:10] |
This is not supported. However, each drawing tool has 8 custom configurations that you can use: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DrawingToolConfiguration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-25 18:20:37] |
Thanks for the quick reply. I presume the answer is no, to both creating a new tool as well as modifying / enhancing an existing tool. If that is the case, is this ability planned? If so, is there a section of the forums / board that shows requested features and extimated build they will be in? Again thanks for your time as I learn my way around Sierra and how it does business and support. John Date Time Of Last Edit: 2016-05-25 18:26:47
[2016-05-25 18:40:56] |
You can create drawing tools but not ones which would be listed on the menu. They are ones that could be used through Control Bar buttons. Information about this is documented here: http://www.sierrachart.com/index.php?page=doc/doc_MouseAndMenuInteractionFromACStudy.html There are no further capabilities planned other than some improvements to what is documented in the link above. There is no place listing features which will be added because we do not know when they will be done and if they will be done. It would be misleading if this was officially posted. Refer to: Notice: Suggestions (Currently not accepting) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-25 18:42:11
