Date/Time: Wed, 01 Jan 2025 14:11:12 +0000
Header Line Error
View Count: 808
[2016-05-25 13:30:55]
User96015 - Posts: 55
Dear sir,
I need to build an ACSIL which opens a TXT file to fish some data.
Now I' m not very able with c++, particulary about including header.
Now I try to insert this line:
#include <sstream>
#include <fstream>
#include <string>
#include "sierrachart.h"
But they generate some errors, but I think because there are conflicts with sierrachart.h file,
because I try to paste the same code with Windows Console and there aren' t any error and it works fine.
I'm compiling with VS2013.
In attachment compile errors.
Let me know as soon as possible thanks.
imageCompile.png / V - Attached On 2016-05-25 13:30:23 UTC - Size: 53.79 KB - 271 views
[2016-05-25 18:01:35]
Helping with those compiler errors is completely outside the scope of our support.
For file reading and writing we recommend using this header file and the functions that it contains:
http://www.cplusplus.com/reference/cstdio/
