Date/Time: Wed, 01 Jan 2025 14:24:10 +0000
Multiple Chart Books open simultaneously
View Count: 3655
[2016-05-25 12:07:41] |
SK - Posts: 33 |
How to have multiple chart books open simultaneously? Currently charts in a single chart book are active. If I have to have charts in other chart books open , they need to be detached . Is there a way to just detach multiple chartbooks or have multiple chartbooks open at the same time. Usually segregate various charts based on a criteria I use. Thanks |
[2016-05-25 16:55:03] |
Only one Chartbook can be visible at a time as is documented: http://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html If you want to have multiple Chartbooks visible at a time, use a new instance: http://www.sierrachart.com/index.php?page=doc/doc_DTCServer.php#UsingDTCServerForDataAndTradingInAnotherSCInstance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
