Date/Time: Tue, 15 Sep 2026 12:34:34 +0000
[User Discussion] - Request for simple "Alert code"
View Count: 1145
[2016-05-25 06:38:04]
EuropeanTrader - Posts: 290
can anyone please create a study collection or some sort of alert - dot on a barchart where there would be 2 consecutive closes in one direction?
So for example, if day 1 is down close and day 2 is down close- there should be a blue dot or something below that day 2 bar. And if day 1 closes up and day 2 closes up as well, there should be a red dot above day 2 bar.
Obviously if consecutive closes continue, dots would continue to show as long as there are "Two consecutive closes in one direction".
Here is an example of 2 consec. down closes: http://www.sierrachart.com/image.php?Image=1464158168534.png
and here with 2 conse. up closes: http://www.sierrachart.com/image.php?Image=1464158245197.png
Thank you very much if anyone is capable to write such an alert !!
[2016-05-25 13:42:58]
Sawtooth - Posts: 4352
Try this:
Add two instances of the Color Bar Based On Alert Condition study, one for each color/direction.
Use these formulas on the Alerts tab of the respective study:
Two consecutive up closes:
=AND(C>C[-1],C[-1]>C[-2])
Two consecutive down closes:
=AND(C<C[-1],C[-1]<C[-2])
Choose your Draw Style and color.
[2016-05-25 13:55:47]
jackw - Posts: 57
Attached is a study collection that will give you your blue/red dots.
attachmentTwoCloses-.StdyCollct - Attached On 2016-05-25 13:55:22 UTC - Size: 18.7 KB - 542 views
[2016-05-25 15:49:19]
Thank you to both of you!
I really appreciate it.
