Date/Time: Fri, 20 Sep 2024 01:01:21 +0000
InfinityAT doesn't use the attached orders
View Count: 1507
[2013-07-11 18:11:42] |
HeavyMike - Posts: 25 |
I'm trying to use the attached orders in SC with InfinityAT, but it looks like the DOM on InfinityAT is what the trade uses for the bracket order. The goal is to use the trailing stops in SC, how do I do that? Can I have it so that it reflect the adjusted trailing stop in the InfinityAT Dom? Cheers! -Mike |
[2013-07-11 18:32:09] |
Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
