Date/Time: Wed, 01 Jan 2025 13:56:04 +0000
Problem with the duration of a bar in charts that are not based on time (Vol, Renko,etc)
View Count: 980
[2016-05-24 14:27:34] |
fobglobal - Posts: 51 |
I have noticed lately, that when a bar lasts more than 5 min (Renko, Vol, etc)and finally It closed the duration of the bar is 5 minutes. I mean if the duration of the bar is less than 5 min the time that is displayed is the real. If the duration is more tan 5 min the time that is displaed when the bar closes is 5 min. Example: real time 3:08 displayed time when bar closes 3:08 real time 13:08 displayed time when bar closes 5:00 thanks |
[2016-05-24 17:11:31] |
When you refer to the time that is "displayed" what specifically are you referring to? All of this is very vague from our perspective. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-25 13:26:29] |
The time that took to complete the creation of the bar (open to close). I mean in a chart based on time, for example in a 60 min chart the time to créate a bar is 60 min. But when you have volumen charts, renko charts the time to créate each bar is variable. So when the time to créate a bar is more than 5 min for example 9 min and I want to check how long did it take to form that bar the time is 5 min no 9 min. Thanks |
[2016-05-25 17:11:33] |
Provide us an image of the chart showing this. Add the Bar Duration study to the chart. Use the Tools >> Arrow tool to draw an arrow pointing to that bar and explain how you are coming to this conclusion. Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-26 14:22:35] |
I am sending you a set of images to explain in sequence what I am trying to explain. I hope this time be clearer to understand. Thanks http://www.sierrachart.com/image.php?Image=1464272222769.png http://www.sierrachart.com/image.php?Image=1464272281786.png http://www.sierrachart.com/image.php?Image=1464272327371.png http://www.sierrachart.com/image.php?Image=1464272354787.png http://www.sierrachart.com/image.php?Image=1464272378658.png http://www.sierrachart.com/image.php?Image=1464272405159.png |
[2016-05-26 18:40:06] |
You are providing too many screenshots and it is not helpful or appreciated. We do not know how you are coming to the conclusion that a bar time length is 5 minutes when it actually is not. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-26 18:43:25] |
We are looking at the Bar Time Duration study. We are making sure it is working properly.
[2016-05-26 18:53:29] |
We understand the reason for the problem now. You are looking at the Bar Time Duration study. There is an issue with this when the chart bars are not based upon a fixed amount of time. We will correct this in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-27 13:21:30] |
Please let me know when it´s done. thanks
[2016-05-27 13:44:58] |
It is done. Update to the latest prerelease with Help >> Download Prerelease.
[2016-05-27 15:45:27] |
It Works ok. Thanks
