Date/Time: Sat, 04 Jan 2025 08:16:25 +0000
Malware detected: win10 64bit stable channel. 1415->1416
View Count: 1237
[2016-05-24 00:10:30]
kinghat - Posts: 120
when going from 1415->1416 i got this notification from windows. obv its a false positive but something you should be aware of.
imageMSASCui_2016-05-23_19-06-26.png / V - Attached On 2016-05-24 00:10:09 UTC - Size: 90.87 KB - 317 views
[2016-05-24 01:21:30]
Interesting we do not see this using Microsoft Security Essentials which is the same as that program.
[2016-05-24 01:27:33]
i didnt get the msg till the installer finished and started loading SC 1416 from 1415. it popped up while it was loading. not sure.
[2016-05-24 03:30:00]
OK we will see if there are other reports.
[2016-05-28 18:44:09]
User13668 - Posts: 294
Yep. I get this exact same issue when downloading v1420 onto a new laptop with no previous SC installation.
[2016-05-28 21:59:36]
Refer to:
https://www.sierrachart.com/index.php?page=doc/download.php#AntivirusSoftwareFlaggingInstaller
[2016-05-28 22:11:06]
Also have a look at the results here:
https://www.virustotal.com/en/file/d7d88352c3fdc685603e74ced644ef39dd13fce7be949231872c4b7892457a82/analysis/1464472828/
[2016-06-02 02:08:18]
Could someone who is encountering this problem use our latest installer two still see if they run into this.
We made a change which might bypass the detection.
[2016-06-02 17:30:37]
If you don't get any other answers, I will try when back from leave on 14th June.
[2016-06-09 06:02:39]
just had this happen after going to 1426 again.
imageMSASCui_2016-06-09_00-58-10.png / V - Attached On 2016-06-09 06:02:35 UTC - Size: 91.02 KB - 271 views
[2016-06-09 06:07:13]
We will contact Microsoft about it again now.
[2016-06-09 06:39:19]
We have made the submission here to Microsoft:
https://www.microsoft.com/en-us/security/portal/submission/submit.aspx
Hopefully we will hear from them soon.
[2016-06-09 06:41:01]
The submission can be tracked here: https://www.microsoft.com/security/portal/submission/submissionhistory.aspx?SubmissionId=c5f4a96b-ae34-410e-8aad-60d3ebab315b
