Date/Time: Wed, 15 Jan 2025 21:32:54 +0000
Plans for 64-bit Sierra Chart, or a way to avoid hitting memory limits?
View Count: 1804
[2016-05-21 13:41:36]
User37537 - Posts: 78
Hello support,
Was just wondering if there are any plans to release a 64-bit version of sierra chart in the near future. Recently I have been trying to backtest entry techniques and I am quickly hitting the 4gb limit when loading footprint and various other charts on very small timeframes spanning back multiple years.
In the meantime (or if the answer is no), is there a way to change the date range for multiple open charts at the same time? This would be useful for example if I want to practice trade a specific month or timeframe in the year 2014. Manually setting the timeframe of all open charts in my chartbook each time I start a practice session would be very time consuming. Perhaps a way to add this as a checkbox for linked chart settings?
[2016-05-21 21:40:56]
There are no plans for a 64-bit version now.
You need to use the Chart Linking >> Days to Load setting:
http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#LinkNumber
[2016-07-10 11:00:35]
doctor10 - Posts: 78
Echoing support for a 64bit version. Have used siera chart for over a decade, and most of my studies are now limited by the 4GB limits of the 32 bit program
[2017-09-15 13:20:13]
User745051 - Posts: 17
I have so many charts up im afraid its going to crash on me when the market heats up. please look to move into 64bit version. the days of Windows 95 is over ;)
[2017-09-15 17:48:12]
What you need to do is use additional instances of Sierra Chart:
http://www.sierrachart.com/index.php?page=doc/NewInstance.php
If you have a lot of charts open, it is better to distribute that processing among multiple instances.
[2017-09-19 06:13:05]
When I have tried doing that it has not downloaded historical data for my charts...? but remains in the original instance.
[2017-09-19 17:31:59]
Refer to this section here:
Using DTC Server for Data and Trading in Another Sierra Chart Instance: Historical Data and Missing Historical Data
If there still is a problem, go to one of the charts in the new instance and select Edit >>Delete All Data and Download.
Provide a copy of the Message Log by following these instructions:
