Date/Time: Fri, 10 Jan 2025 16:17:23 +0000
[User Discussion] - Amazing Feature, not sure if possible (if not needed)
View Count: 1013
[2016-05-20 20:33:14] |
User15952 - Posts: 132 |
Is it possible to have a button or keyboard shortcut where you can toggle your studies on and off via the “Hide Study” checkbox. Could this be done in ASCIL?
[2016-05-22 02:35:58] |
Not exactly this but what is available is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#HidingShowingStudy ACSIL can hide and show studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-23 01:22:15] |
User948528 - Posts: 108 |
+1, keyboard shortcuts to hide/show specific studies on any selected chart or switch loaded study collections would be amazing.
Date Time Of Last Edit: 2016-05-23 01:22:40
[2016-09-25 23:44:40] |
Kinobe - Posts: 86 |
+1
