Date/Time: Tue, 29 Sep 2026 15:36:52 +0000
SubgraphRef - CPU exception
View Count: 1231
[2016-05-20 00:32:30]
User754985 - Posts: 109
Why would the following piece of code generate a CPU exception?
SCSubgraphRef CurrentPosition   = sc.Subgraph[8]
sc.Autoloop=1;
int Result=0;
Result=sc.BuyOrder(NewOrder);
if (Result>0)
CurrentPosition[sc.Index]+=Result;
And if CurrentPosition is defined as a Persistent Variable - all works fine..
[2016-05-20 00:35:55]
This is not safe:
Should be:
CurrentPosition[sc.Index] = Result + CurrentPosition[sc.Index];
[2016-05-20 00:46:50]
This did not work either...
[2016-05-20 00:54:18]
This means there is some other unidentified problem which we cannot see.
You will have to find it and resolve it on your own.
Date Time Of Last Edit: 2016-05-20 00:54:33
[2016-05-20 00:57:10]
What are the typical causes of "CPU exception"?
division by zero, wrong type casting, ...?
[2016-05-20 02:10:17]
Access violations and integer divide by zero are the most common exceptions.
Access violations can be caused by a memory corruption in one area of code causing a problem with other code that has no problem to begin with.
Once an exception occurs, the process is no longer in a stable state and has to be restarted. Otherwise exceptions can continue to occur even though the problem has been solved in the custom studies DLL.
Date Time Of Last Edit: 2016-05-20 02:11:29
