Date/Time: Wed, 16 Sep 2026 00:08:14 +0000
[Programming Help] - sc.StorageBlock limitations
View Count: 1745
[2016-05-20 00:22:07]
User754985 - Posts: 109
sc.StorageBlock is said to be of 512b.
Yet, I cannot fit all of the following variables into it:
struct s_PermData
    int ChartPosition;
    double Lastentryprice; //or reduced to float
    int Lastentrybar;
    int LastIntOrderId;
    int LastPTargetOrderId;
    int LastSLOrderId;
s_PermData* PermData;
PermData = (s_PermData*)sc.StorageBlock;
in the beginning of my code I retrieve these values and at the end- save into sc.StorageBlock.
CurrentPosition=PermData->ChartPosition;
      if (CurrentPosition==0)
        entrybar=i;
        entryprice=(double)sc.Close[i];
        TargetOrderID=0;
        StopOrderID=0;
        IntOrderID=0;
      else
        entrybar=PermData->Lastentrybar;
        entryprice=PermData->Lastentryprice;
        IntOrderID=PermData->LastIntOrderId;
        TargetOrderID=PermData->LastPTargetOrderId;
        StopOrderID=PermData->LastSLOrderId;
PermData->ChartPosition=CurrentPosition;
      PermData->Lastentryprice=entryprice;
      PermData->Lastentrybar=entrybar;
      PermData->LastIntOrderId=IntOrderID;
      PermData->LastPTargetOrderId=TargetOrderID;
      PermData->LastSLOrderId=StopOrderID;[/i]
A double and 1 int - work. 5 ints - work. A float and 2 ints - work...All of them together - generate a CPU exception at runtime.
Why would this be?
Is there a way to define a second StorageBlock for the study instance?
[2016-05-20 00:39:31]
All we can say is you must be doing something wrong if you are getting an exception.
There is only one StorageBlock per study.
[2016-05-20 00:54:41]
If I do not assign/retrieve them, just declare - all works fine..
But i commented/uncommented each single statement of usage to corner the error and each of them works by itself..or in combination (like described)...but not all of them together...that's why i thought of a Storageblock memory limitation..
