Date/Time: Wed, 01 Jan 2025 13:59:49 +0000
Option Symbol Format
View Count: 746
[2016-05-19 17:34:54] |
User713273 - Posts: 409 |
What symbol context would AAPL be when using 94.5, 95.5 contacts? I know using standard symbols is AAPL-OPT-20160520-94-P-SMART-100-USD, would it be AAPL-OPT-20160520-94.5-P-SMART-100-USD? http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Option |
[2016-05-19 17:43:29] |
Yes that does look correct but you should do some testing to be sure.
