Date/Time: Wed, 01 Jan 2025 14:01:11 +0000
J column copy across sheets
View Count: 775
[2016-05-19 09:52:47] |
phaedonk - Posts: 352 |
Is there an easy way to copy the J column across multiple sheets? I have a spreadsheet where I am tracking 15 markets. Most of the logic in the formula source sheet's J column also applies to the others (e.g. time to disable auto trading etc.). The few that have special settings I will gladly change by hand. It is my understanding that the J column will not automatically copy to other sheets (which is the right way for sure) but I am looking for a hint of an alternative way maybe. |
[2016-05-19 17:49:28] |
If you want to copy the final formula result you could use a cell reference: http://www.sierrachart.com/index.php?page=doc/doc_Spreadsheets.html#CellandRangeReferences We will also look into adding an option to control whether to copy the J column from the Formula Source Sheet. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-19 18:17:35] |
Sawtooth - Posts: 4144 |
+1
