Date/Time: Fri, 20 Sep 2024 01:12:49 +0000
TransactToSierraBridge in version 994
View Count: 1734
[2013-07-11 01:46:33] |
hft168 - Posts: 31 |
Hi S.C. Support, With version 992 or older, I was able to load 2 or 3 TranAct accounts with seperate S.C. installed on different folders on the same computer. (with 2 or 3 T@ icons shown in system tray) However, with v994, it seems only one TransactToSierraBridge (v 1.2.0.6) can be loaded, and the second one seems to disconnect the first one for its own connection, and I no longer see more than one icon in the systemtray, or see the second icon with an error. Wonder if this is specific to v994 only. Thanks. |
[2013-07-11 09:20:06] |
We are aware of this. We are planning a new release during the next 5 hours which will solve this. Thank you for your patience.
[2013-07-11 15:28:59] |
TransAct support - Posts: 8 |
This was due to a change I requested to use the Transact Standard Port number. It was an attempt to fix an issue with firewalls. I have modified the application to resolve it and Sierra will include it in the next release. |
[2013-07-11 18:48:47] |
We have released this new version of the bridge. We apologize for the delay. It is in our latest prerelease. You can update with Help >> Download Prerelease.
