Date/Time: Wed, 01 Jan 2025 14:03:21 +0000
SC Data Feed - Additional Levels of Market Depth for Eurex
View Count: 834
[2016-05-19 06:44:21] |
Futurestrader77 - Posts: 126 |
Dear Support Team, did you here anything back from Barchart regarding the 20 level of depth each side for Eurex? Thank you! |
[2016-05-19 10:03:47] |
Yes they said it will be later in the year but we do have our back up data feed we can use on one of the servers that does have 20 levels of depth.
