Date/Time: Wed, 01 Jan 2025 14:13:51 +0000
Multiple chartbook saves
View Count: 735
[2016-05-18 20:42:54] |
User515197 - Posts: 5 |
Is it possible to save chartbooks in a batch Instead of individually? |
[2016-05-18 23:20:57] |
Yes. File >> Save All.
