Date/Time: Wed, 01 Jan 2025 13:37:13 +0000
User Email
View Count: 872
[2016-05-18 18:59:15]
Sierra Chart - Max - Posts: 5771
I have another client with problems using this indicator. It is not on time and often misses seconds. Do you have any idea to have it working properly?
Sierra Chart Support
Date Time Of Last Edit: 2016-05-18 19:00:04
[2016-05-18 19:02:54]
Open the Study Settings for the Countdown Timer study:
http://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#AddingModifyingStudies
Set the Display Continuous Time Countdown Based on Real-Time Clock Input to Yes.
[2016-05-19 16:30:51]
User625993 - Posts: 7
Hello, in one case the solution worked, in another case in the 1 minute chart the countdown does start at 2 minutes and ten seconds and in the 5 minutes chart the countdown does start at 6 minutes and 15 seconda. Maybe is there some other settings to change?
Thank you
Kind Regards
Patrizia
[2016-05-19 17:44:29]
The described problem is an indication the computer's clock is not set correctly.
Refer to help topic 38 for instructions:
Https://www.sierrachart.com/index.php?l=helpdetails38.html
