Date/Time: Wed, 01 Jan 2025 14:12:24 +0000
adding a custom study
View Count: 843
[2016-05-18 16:10:37] |
User25244 - Posts: 123 |
How does one add a custom study i hav it in a .dll format tried drag and drop ty |
[2016-05-18 16:31:30] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_DLLUsage.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-18 20:47:25] |
i have viewed your instructions to no avail. i have downloaded a dll indicator file to my computer Windows 8 when i go to data files and select it cant find the file I have it downloaded so cant seem to find the problem this is not an existing custom study but one downloaded from a forum i belong to please help ty |
[2016-05-18 23:20:23] |
The instructions do not say to do this: when i go to data files and select it cant find the file
Or it is not clear exactly what you are doing. You will see the custom studies through Analysis >> Studies >> Add Custom Study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
