Date/Time: Wed, 01 Jan 2025 14:09:26 +0000
customize menu item
View Count: 1621
[2016-05-18 13:21:59] |
ktfroy - Posts: 85 |
Can the color choices be user-adjusted in the right click/colors option for Drawings?
5-18-2016 9-15-27 AM.png / V - Attached On 2016-05-18 13:19:18 UTC - Size: 13.84 KB - 342 views Attachment Deleted. |
[2016-05-18 17:03:55] |
These can be customized. This is explained in this section here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#QuicklyChangingColors Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-19 12:42:34] |
Great - thx Is there a way to have more saved configurations for tools seen on the pop up menu? Only 1 show up for drawing tools. |
5-19-2016 8-21-31 AM.png / V - Attached On 2016-05-19 12:41:48 UTC - Size: 18.11 KB - 280 views |
[2016-05-19 16:58:30] |
Refer to: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#CustomizingCDMenu Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-19 16:58:51
[2016-05-19 17:06:48] |
Found it - thanks
Date Time Of Last Edit: 2016-05-19 17:14:17
