Date/Time: Tue, 14 Jan 2025 22:53:46 +0000
(ACSIL) In a study, how to get notified when I start drawing a line in the chart
View Count: 1076
[2016-05-18 05:08:07] |
User288988 - Posts: 2 |
In my study, i want to be notified when i start drawing a line by pressing the mouse button, and the mouse button is not released yet, then i can highlight some bars and give some tips in the study
[2016-05-18 06:03:17] |
Refer to this page: http://www.sierrachart.com/index.php?page=doc/doc_MouseAndMenuInteractionFromACStudy.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-18 06:40:17] |
it writes: These Pointer events are only passed to custom studies on the chart when the active tool is Tools >> Pointer, Tools >> Chart Values, or Tools >> Hand (Version 1374 and higher). when i'm drawing a line, the active tool will be Tools >> Line, as the document described, those events can't be passed |
[2016-05-18 08:23:50] |
Yes actually this is true.
[2017-05-20 17:36:41] |
phaedonk - Posts: 352 |
Is there a reason why pointer events cannot be monitored with a drawing tool enabled? I'd like to use a horizontal ray, capture its price (via mouse button monitoring) in a persistent variable and modify orders when this is hit. Date Time Of Last Edit: 2017-05-22 20:10:05
[2017-05-23 04:47:11] |
This will be supported in the next release and the updated documentation is here: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events: Receiving Pointer Events Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
