Date/Time: Fri, 20 Sep 2024 00:47:59 +0000
Chart Drawings Jumping Around
View Count: 1906
[2013-07-10 22:45:04] |
Futures Operator - Posts: 239 |
Please see video in link for demonstration of a trendline drawn on larger timeframe historical chart moving around on an intraday 15 minute chart (third from left) it's copied to, as price moves. Same drawing on the 60 minute chart doesn't seem to be affected. http://screencast.com/t/gQ1YuspJ2 Date Time Of Last Edit: 2013-07-10 22:47:19
[2013-07-11 10:21:21] |
Please provide us a simple Chartbook containing 2 charts and no studies to demonstrate the issue and we will have a look. Although it seems doubtful we would find anything wrong and there is an explanation for why you see what you do. Make sure the destination chart for the Chart Drawings has a starting Date-Time which is earlier than the first point of the Line. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-11 10:24:21
[2013-07-11 10:23:53] |
Also, please refer to this page here: http://www.sierrachart.com/index.php?l=doc/helpdetails34.html It really is very doubtful there is any issue here. You need to understand the reasons why these kinds of things can happen and how we really cannot solve every possible kind of scenario someone creates. We are not willing to spend time on this. Most likely this just has to do with mapping floating-point values into an integer coordinates system. Read over the information given in the linked to help topic and take our advice in the prior post. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-11 10:24:56
