Date/Time: Sun, 29 Dec 2024 16:15:26 +0000
Price level marker suggestion/request
View Count: 1081
[2016-05-17 21:12:18]
User94199 - Posts: 13
I would like to suggest 2 things
1) ability to modify text on "Date Marker tool", so trader can write down into chart note that marker marks time for FOMC or some other market moving event
2) request for price level marker. Same mechanism as Date marker, but marking price level, or price range + modify text to post notes
A lot can be marked by lines, horizontal rays, or extended rectangle tools, but if you have too many levels, charts becomes difficult to read. Having a tool that shows up just at price level, or just in lock fill space, would help keep it clean.
Attaching screenshot. Currently I'm using horizontal ray, with anchor in future time, outside of charts scope, so it only shows price. It is difficult to manipulate it, as you cannot select it if anchor is outside of chart.
Thank you, have a nice day
imagePrice level marker.png / V - Attached On 2016-05-17 21:11:08 UTC - Size: 4.76 KB - 277 views
[2016-05-18 03:27:54]
tradernikki - Posts: 41
+1 for this feature
[2016-05-18 06:22:09]
1. We will look into this.
2. Do you know that you can set text on Horizontal Lines:
http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ModifyText
There is also the Text tool.
There is also this study Subgraph Draw Style: Subgraph Name and Value Labels Only :
http://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#DrawStyle
Otherwise, we are not accepting any new suggestions.
