Date/Time: Thu, 28 Nov 2024 01:44:53 +0000
horizontal line in trade dom at the middle of the dom window
View Count: 1878
[2016-05-17 20:18:13] |
Cavalry3162 - Posts: 523 |
hello support, could we get a horizontal line at the middle of the dom window? jigsaw has that and i find it very usefull to identify (little) divergences. when you center it, it will be at certain prices and will scroll with the window (and stays there) until you recenter again, then it will be again in the middle of the window. thanks, Andreas |
2016-05-17_16-14-53.png / V - Attached On 2016-05-17 20:17:34 UTC - Size: 207.51 KB - 690 views |
[2016-10-20 04:24:50] |
tradernikki - Posts: 41 |
+1
[2016-10-20 21:25:39] |
User150371 - Posts: 70 |
+1
[2016-10-23 02:29:45] |
Not sure we understand the complete logic of the horizontal line.
[2016-10-23 06:10:22] |
Hello SC, thank you for looking into this. it is meant to be like this: i press "Center DoM" -> the horizontal line will be drawn at the middle of the dom (right between the best bid and best ask) and stays at that price regardless if i scroll or the prices move.. it just stays at the price where it was drawn since last executing the center function. if thats the case, price can move away from the line and one will be able to see differences in movement when you have 2 or more doms side by side.. thank you, Andreas |
[2016-10-25 20:46:58] |
OK we understand . We will make a note to add this. Not sure how soon we can get to it though.
[2016-10-26 13:17:18] |
thank you for considering this.. it will be a very low hanging fruit due to the fact that you can already draw lines on the dom and it will help dom traders a lot.. just for the records, it would be great if the line would be drawn through the entire dom window (full width) and a color setting would be great too.. Andreas |
[2017-06-06 05:20:19] |
User521830 - Posts: 5 |
Hi, has it been already implemented? cheers, Jano |
[2018-01-31 06:43:18] |
whats1thingnow - Posts: 407 |
+1
[2018-01-31 08:42:12] |
it is in since forever..
