Date/Time: Sun, 29 Dec 2024 15:27:50 +0000
Weekly Period OHLC
View Count: 805
[2016-05-17 18:01:18] |
SK - Posts: 33 |
Am using Period OHLC set to week 1 to get this weeks high and low. However for ES futures, how to do just a RTH high low and show both globex and RTH high/lows? Pls. see attached. I have my chart set to use evening timeframe and regular hours as well. Any thoughts appreciated |
2016-05-17_13-50-46.jpg / V - Attached On 2016-05-17 17:58:29 UTC - Size: 468.91 KB - 293 views |
[2016-05-17 18:32:22] |
This requires using a separate Regular Trading Hours chart and putting the study on that chart and then overlaying it to the full 24 hours chart. Refer to the documentation here for this: http://www.sierrachart.com/index.php?page=doc/doc_StudyPriceOverlayStudy.php#OverlayStudyDiffSessionTimes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-17 19:18:18] |
SK - Posts: 33 |
Ok thnx
