Date/Time: Sun, 29 Dec 2024 15:09:58 +0000
potential bug - TS - Sequence issue with recent versions
View Count: 719
[2016-05-17 17:30:20]
ejtrader - Posts: 688
SC team - There seems to be a bug introduced with recent versions where the millisecond - sequence counter increment is no longer correct. This issue started with recent versions. Would you please review.
PS: This is not specific to any data provider.
it used be :
hh:mm:ss.001
hh:mm:ss.002
it's now:
hh:mm:ss.001
hh:mm:ss.000
hh:mm:ss.001
Date Time Of Last Edit: 2016-05-17 17:31:12
imageSC_TS_Sequence_Issue.jpg / V - Attached On 2016-05-17 17:29:38 UTC - Size: 195.59 KB - 301 views
[2016-05-17 17:38:02]
Yes we know about this. We are quite unhappy with this error. We corrected one problem related to this and it unexpectedly caused this one.
Although in almost all cases, it does not have an obvious consequence. It has been solved in version 1515 and we will have that out as the main release in another day or so.
Date Time Of Last Edit: 2016-05-17 17:38:54
