Date/Time: Sun, 29 Dec 2024 15:43:49 +0000
[User Discussion] - Non chart Programming for SC ?
View Count: 753
[2016-05-17 09:48:27] |
User742717 Mike - Posts: 86 |
Hi, I have a question, I was looking at programming my own feature (a better quoteboard) for SC, but ACSIL seems only for charts? Ie, ACSIL doesn't support multiple symbols nor any windowing access. Is this correct or can SC be extended? (I know there's the text export study) Cheers Mike. Date Time Of Last Edit: 2016-05-17 09:50:47
[2016-05-17 18:55:56] |
It is possible to access other symbols using ACSIL. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ACSILRefOtherTimeFrames.php ACSIL does not support using windows. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
