Date/Time: Mon, 23 Dec 2024 23:48:13 +0000
BookMap
View Count: 24268
[2016-06-17 07:07:08]
Post this through a separate Support Request. We will not accept this in a User Discussion thread. Also how you describe it is how it should be working but we will check again.
[2016-06-20 01:19:23]
User15952 - Posts: 132
Market Depth Historical Graph
[2017-02-14 19:39:18]
JVonD - Posts: 9
Totally awesome! Thanks a bunch amirN!
Is there anyway to make it record more of the book. Image Example Attached - crude
image17-02-14_12-30-26.png / V - Attached On 2017-02-14 19:37:30 UTC - Size: 72.3 KB - 1894 views
[2017-02-14 21:12:18]
We recommend using the Market Depth Historical Graph feature:
https://www.sierrachart.com/index.php?page=doc/MarketDepthHistoricalGraph.php
[2017-02-15 13:48:46]
amirN - Posts: 159
I am afraid it can only display 10 levels on the Bid and 10 on the Ask.
I am not going to upload my later improvements as SC has a version out (the above post).
Regards
Amir
[2017-04-13 12:29:29]
User30743 - Posts: 365
hi amir, would u be willing to provide .cpp file of this book map?
