Date/Time: Wed, 01 Jan 2025 14:16:24 +0000
Feature request
View Count: 1092
[2016-05-17 08:37:01] |
User19057 - Posts: 6 |
I'd like to request functionality (check box?) to quickly hide and unhide chart drawings that come from the "Copy Chart Drawings From Charts #'s. Thank you. PS I'm a transact user via Infinity Futures Date Time Of Last Edit: 2016-05-17 08:37:45
[2016-05-17 08:47:23] |
This is already supported. Use Chart >> Hide Chart Drawings. Although this applies to all drawings. You can also hide them in the source chart and they will be hidden in the destination charts as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-17 18:42:49] |
thanks for the speedy response, I have a chart that is fed drawings from 3 other charts in the workbook. Rather than go into each "feeder"chart and hide the drawings it would be much more efficient if there was a single toggle to hide/unhide drawings from other charts. Currently to "hide" the drawings I "cut (ctrl X)" the chart numbers out of the Copy Chart Drawings From Charts #'s field hit apply then paste (ctrl V) them back in when to unhide them. A check box would be less cumbersome. Date Time Of Last Edit: 2016-05-17 18:44:18
[2016-05-17 18:57:17] |
But why not use Chart >> Hide Chart Drawings? Do you have other drawings that were drawn on that chart that you want to keep visible? If so we can add another command specifically for drawings from other charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-18 05:57:17] |
"Do you have other drawings that were drawn on that chart that you want to keep visible?" That is exactly correct. What I'm doing is drawing lines on 2 TPO charts (daily & weekly) and higher time frame charts and projecting them onto a candle stick chart I use for triggering trades. The ability to toggle the TPO chart drawings on & off the trigger chart while leaving the "trigger"chart drawings visible would be very useful. Hope that makes sense many thanks |
[2016-05-18 12:55:56] |
Sawtooth - Posts: 4144 |
+1
[2016-05-19 11:00:48] |
This will be added to the next release.
[2016-05-19 18:09:34] |
great, I look forward to it. many thanks in advance. |
