Date/Time: Wed, 01 Jan 2025 14:29:07 +0000
Australian 10Y Bond Futures - CQG Feed - Continuous contract shows current contract only
View Count: 1878
[2016-05-17 02:27:50] |
Dema - Posts: 42 |
Hi Team, I am trying to use the continuous futures for the Australian 10Y Bond Futures via CQG (symbol = F.US.HXSM16), but it is only showing data for the current contract. Could you please review/assist? Thanks, Andrew Date Time Of Last Edit: 2016-05-17 02:28:07
[2016-05-17 02:42:24] |
There is going to be a problem with this. The rollover rules have to be set up, and CQG does not have historical data for expired futures contract. We would have to maintain that on our side and that is not currently done. Are you trading this through AMP? If so, we can contact them about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-17 02:43:34] |
Actually, we can see that historical data is being maintained for this market. So we just need to set up the rollover rules. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-17 03:44:00] |
The Symbol Settings for the Symbol have been updated. Follow the instructions here to update them: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps After that is done you can select Chart >> Reload Chart and the prior contract months will be downloaded and displayed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-26 00:39:27] |
Dema - Posts: 42 |
Confirming this worked perfectly after using your instructions. Thanks so much!
