Date/Time: Sun, 29 Dec 2024 15:04:51 +0000
Duplicate and/or sync charts
View Count: 814
[2016-05-16 17:11:49] |
User656410 - Posts: 12 |
Hello, I used the duplicate chart option to duplicate the seven charts I use. All of the charts are the Nasdaq emini, just different time frames. On each chart I use identical horizontal lines and a 20 exponential moving average. Each day I move the horizontal lines on the 5 minute chart. How can I have the horizontal lines move the same on all of the charts, instead of changing the horizontal lines manually? Thanks you |
[2016-05-16 18:45:42] |
Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
