Date/Time: Sat, 26 Sep 2026 03:08:47 +0000
Renko Flex study
View Count: 1406
[2016-05-16 16:51:54]
User738543 - Posts: 9
can anyone help me setup a Renko Flux chart. I tried following the instructions, but am not able to get it to look like the SC picture that follows the trend.Thanks
[2016-05-16 18:44:21]
Refer to the documentation here:
Renko Bar Charts
If you need further help, we need to understand specifically what you need to do.
[2016-05-16 18:57:10]
that documentation is what I was referring to. Specifically, the chart at the bottom of the page which forms a ' Trend Channel '. I can't seem to format it properly. I get renko candles, but not the smooth even channels as in the picture. Thanks for your help.
[2016-05-16 19:00:10]
For what symbol do you want to use Renko bars for?
[2016-05-16 19:11:45]
lol-well that's another problem. I just started my free trial today, and the only symbol that I am able to get is in the sample chart, which is the euro/ usd. no other symbols seen to populate when I type on the chart
[2016-05-16 23:15:00]
RESOLVED--thru trial and error, I figured it out. What a great looking chart. Thanks to all that helped
[2016-05-17 01:08:20]
If you still have a problem give us another symbol that supposedly do not get any data for and provide a copy of the Message Log by following these instructions:
Only Forex and CFD symbols are going to update in real time, the others will not. Refer to:
What is Included in the Free Trial?
