Date/Time: Sat, 03 Oct 2026 20:02:52 +0000
calling sc cci method with referenced base chart data
View Count: 1930
| [2013-07-10 19:58:32] |
| onnb - Posts: 666 |
using this api int chartId = sc.OpenChartOrGetChartReference(chartParameters); SCGraphData baseGraphData; sc.GetChartBaseData(chartId, baseGraphData); I'd like to use the baseGraphData to now call sc.CCI / ATR / etc... Any thoughts on how and if possible to do that since they require subgraps as outputs and the referenced chart is not the same as the current chart? It doesn't look like this is possible at this time and just want to make sure I am not missing something. Onn |
| [2013-07-10 22:43:10] |
The only reliable way this will work is if the chart your study function is on has the same number of bars as the chart you are referencing.
