DTC Protocol Discussion Forum
- DTC Protocol Discussion Forum |
- Search Board |
- Control Panel |
- View My Posts / Threads |
- Direct Messages
Date/Time: Tue, 04 Nov 2025 15:43:12 +0000
Bracket orders with several targets
View Count: 3246
| [2016-05-15 20:56:48] |
| vbmithr - Posts: 204 |
When sending a bracket order with several target orders (using defaults settings), SC seems to breach the DTC protocol. It first sends the parent order, then two OCO orders in a row, with one of the OCO order refering to a unknown parent. How are those bracket orders with multiple targets are supposed to be handled by DTC? The doc about bracket order does not mention this situation.
| [2016-05-16 00:58:45] |
Are you sure about this? We will have to test this. This would be completely unexpected.
| [2016-05-16 01:29:55] |
We do not see any problem with this. We just did a test. Both the DTC client in Sierra Chart and a DTC server are in live use for the LMAX trading service without any problems.
| [2016-05-16 14:03:20] |
Indeed it was a (huge) bug in my code: I was not properly handling chunks of data from SC that contains several messages. Apparently it only arise in the case of such multi target bracket orders since I never ever received a packet from SC containing multiple messages before…
