Date/Time: Mon, 05 Oct 2026 03:11:59 +0000
SC Not getting all contract data from CTS data feed
View Count: 1404
[2016-05-15 14:20:00]
Meritus - Posts: 164
Hey Support please advise on the following
My front end CTS trading DOM can access the CBOT exchange traded BOB spread which is the ZB v UB spread in the ratio of 5:4. I can also use CTS to see a chart of this product. I use the CTS feed for SC butr when I go to Find Symbol, CME CBOT fin Futures, UB or ZB then click on Get Spreads, the only spreads that show are calendar spreads and not the Inter-commodity spreads which in this case means the BOB spread. When I click on ZB or ZT and click on Get Spreads there are not inter-commodity spreads either such as the 10yr v 30 yr inter-commodity spreads which I CAN see on my CTS front end.
Please advise how I can pull these spreads from the CTS data feed into SC.
Thanks in advance
[2016-05-15 21:00:15]
BOB has been added. Follow the instructions here to update the Symbol Settings:
You need to select that symbol and press the "Get Symbols" button to get the actual spread contracts for it.
Select one from the list and open a chart.
The other symbols will be added before morning.
Date Time Of Last Edit: 2016-05-15 21:00:25
[2016-05-16 13:00:56]
Hello again,
BOB has indeed been added....TWICE!
Could you please add BUB and NOB. Many thanks in advance
[2016-05-16 16:59:59]
For BOB you need to use BOB.~.CME_F.
The others will be added by the end of the day. We got behind on this because there are a lot of them to add.
[2016-05-17 05:01:51]
Hi Support,
Unfortunately the following 2 exchange traded spreads are still not showing in Find Symbol although I appreciate you have added several others:
BUB 30vUltra Future (1:1)
NCB 10 Ultra Note v 30y Bond Future (2:1)
As I mentioned in my last post the BOB appears twice in the Find Symbol contract listings and when viewed they both appear to be exactly the same contract with a ratio of 5:3 for the June contract. The BUB which I would like you to add is the same underlying (30y v Ultra future) but with a ratio of 1:1
Date Time Of Last Edit: 2016-05-17 05:02:12
[2016-05-17 05:43:32]
These have now been added.
The additional symbol setting for BOB can be deleted through Global Settings >> Symbol Settings.
However, unless you have set up custom Symbol Settings, perform a Full Reset of the Symbol Settings as explained here:
http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#FullResetSymbolSettingsSteps
This is all you need to do to get the latest settings and clear the duplicate.
