Date/Time: Fri, 10 Jan 2025 09:28:07 +0000
New for Sierra Chart
View Count: 3057
[2016-07-13 04:18:26] |
Refer to the documentation about this here: https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#ChangingDataFilesFolder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-27 05:57:34] |
binaryduke - Posts: 373 |
@ User701247 - you may wish to check out www.emojitrading.com which has implemented the tools that you have referenced in your initial query for Sierra Chart
[2016-08-30 04:58:07] |
User701247 - Posts: 117 |
I would like to know on when my current subscription expired. Does anyone have any suggestions? Thanks in advance for any suggestions |
[2016-08-30 05:07:08] |
Your account is not expired. But it will expire in 2016-09-07.
[2016-08-31 08:37:51] |
If you require a usage time extension to practice and learn the programmatic interfaces like ACSIL, let us know. We can do that for you.
[2016-09-04 11:12:10] |
Furthermore, I get 4 days remaining, when I open Sierra Chart and not able to load data. Does anyone have any suggestions on what wrong it is? Thanks in advance for any suggestions Date Time Of Last Edit: 2016-09-05 12:12:09
[2016-09-06 05:44:29] |
Regarding the problem with not being able to load data, we need more of a clear description and we need to know what particular symbol you are having a problem with. Let us know. Just tell us one of the symbols. Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-06 05:45:19
[2016-09-06 13:52:44] |
Please see attached image for Data Setting Do you have any suggestions? Thanks in advance for any suggestions |
[2016-09-06 18:22:55] |
We still do not know what symbol you are having a problem with and we still do not have the Message Log. Refer to post #56 above.
[2016-09-07 04:40:43] |
Symbol : EUS16, which has been worked before. Please see attached file for details Do you have any suggestions? Thanks in advance for any suggestions Date Time Of Last Edit: 2016-09-07 04:45:53
EUS16_Setting.JPG / V - Attached On 2016-09-07 04:42:35 UTC - Size: 89.22 KB - 297 views EUS16_Error.JPG / V - Attached On 2016-09-07 04:45:49 UTC - Size: 98.26 KB - 261 views |
[2016-09-07 05:10:21] |
You are not using the correct symbol. This is the symbol you need to use: ESU16 Select File>> Find Symbol. Enter the symbol into the Selected Symbol box and press Open Intraday Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-07 15:10:35] |
I work now, after expired, I would like to know on whether I can keep using it for studying purpose without subscription or not. Do you have any suggestions? Thanks in advance for any suggestions |
[2016-09-07 17:55:41] |
You will not be able to access any new data, but Sierra Chart will be mostly functional still except for accessing data.
