Date/Time: Sun, 29 Dec 2024 15:24:01 +0000
[User Discussion] - $tick data for Crude Oil (Nymex)
View Count: 736
[2016-05-15 03:39:29]
User636069 - Posts: 26
Hello Folks,
Two questions:
1- Does anyone know what $tick data should be used for crude oil (Nymex) trading? For instance, for S&P500, $tick-NYSE is used. Thanks in advance!
2- Is anyone using the Relative Volume indicator? if so, it would be appreciated if you could share how you use it efficiently? Thanks!
