Date/Time: Thu, 18 Jun 2026 14:03:16 +0000
Chart values for tools
View Count: 1091
| [2016-05-15 01:37:24] |
| User656410 - Posts: 12 |
Hello, Is there a way to use the cursor instead of the cross-hair when using the chart values for tools window, or any window that shows individual candle data? Also, excuse me if there is a one question limit. Is there a way to lock the hand tool? Example; if I'm using the cursor, can I left click and hold to use the hand tool without going back and forth to the tool window. Thanks, Dan |
| [2016-05-15 02:58:01] |
Yes. There are options to hide the vertical and horizontal crosshair lines with the Chart Values Tool. And there is an option to keep the Chart Values tool always active. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValuesToolSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
