Date/Time: Sun, 29 Dec 2024 16:12:03 +0000
upgrade from 1406 failed, Sierrachart can not run
View Count: 655
[2016-05-14 15:34:53]
User567294 - Posts: 47
I try to upgrade from 1406, after installer running aand finished, Sierrachart can NOT run, sierrachart.exe file only 665k in size.
can anybody help?
thanks
rex.
[2016-05-14 20:53:24]
Run the installer again. You can download it from here:
https://www.sierrachart.com/index.php?page=doc/download.php#download
Make sure the "Installation Path" setting is set correctly.
