Date/Time: Wed, 23 Sep 2026 16:34:25 +0000
Strange message during initial start up of Sierra Chart - What are these?
View Count: 1154
[2016-05-13 22:50:00]
FFTrader - Posts: 180
I am connected to a public Wifi in an educational institution.
Noticed that it produces the follow messages from the log (using version 1411) in double quotes:
"Checking for new symbol settings for ib | 2016-05-13 15:44:02
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-05-13 15:44:02
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-05-13 15:44:02
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-05-13 15:44:02
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-05-13 15:44:07
Symbol settings are up-to-date for ib | 2016-05-13 15:44:07
Warning: Caught an exception during the processing of a timer event. | 2016-05-13 15:44:08 *
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-05-13 15:44:12
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-05-13 15:44:12
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-05-13 15:44:12
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-05-13 15:44:12"
After the above log/error message, Sierra Chart waited and then loads.
What is with SSL connection closed by remote side?
[2016-05-13 22:53:18]
This has now been solved.
Update with Help >> Download Current Version.
You should also be receiving an update message when you start Sierra Chart. You need to click the View in Web Browser button to see it.
