Date/Time: Sun, 27 Sep 2026 22:37:57 +0000
IsSwingLowAllowEqual_S does not compile
View Count: 1090
| [2016-05-13 21:35:04] |
| @sstfrederik - Posts: 413 |
using 1408. was this replaced with something else? IsSwingLowAllowEqual_S is used in the source code from the swing high low study in studies6. Thanks. |
| [2016-05-13 22:07:37] |
What is the specific error message that you are seeing?
| [2016-05-13 22:10:25] |
'IsSwingLowAllowEqual_S' was not declared in this scope else if ( IsSwingLowAllowEqual_S( sc, true , IndexToEvaluate, Length.GetInt()) ){ |
| [2016-05-14 11:04:03] |
You need to get the source code for that function from the SCStudyFunctions.cpp file and include it in your CPP file above the function it is called from.
