Date/Time: Sun, 29 Dec 2024 16:17:01 +0000
Settings Says Delta Bars but chart is Renko Bars
View Count: 854
[2016-05-13 21:06:04] |
apollofl - Posts: 95 |
I want Renko Bars that are showing, but the chart settings says Delta Bars. Please help resolve this issue. Thanks |
Private File Private File |
[2016-05-13 22:11:59] |
We are checking on this now.
[2016-05-13 22:34:48] |
This was an inadvertent mistake in the dialog settings. We are fixing this now and putting out version 1413.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-13 22:35:02
[2016-05-13 22:46:03] |
This has now been solved. Update to version 1413 with Help >> Download Current Version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-13 23:00:28] |
As always Thanks for all that you do and your quick response. You guys are The Best.
